I cant find a fuel pump....help
todd776
I can't find a fuel pump or a repair kit for my 1962 johnson seaholrse 10 hp.....I called cust service and they don't have fuel pump for that year and they gave me pt # 18-7043 as number for a fuel pump rebuild kit.......that number is for a carb kit..??? #hats not what I need is it??? Maybee im just out of luck....does anyone know.....
R.Johnson
Re: I cant find a fuel pump....help
Most any of the small engine fuel pump's should work.
todd776
so any of the johnson 10 hp engine fuel pumps should work?? any year???? I'm not a whiz at these kind of things......so I can just connect the hoses and away I go.......???
F_R
Honorary Supreme Mariner
Either 18-7350 or 18-7351. I prefer 18-7351. Either way, you have to re-route the hoses. Get them here at iboats.
R.Johnson
The pump bolts to the intake bypass cover, Any of the smaller pump's that bolts to the bypass cover should work. You may have to lengthen, or shorten a fuel hose, but should bolt right up.
todd776
thanks for all your help....I have one on order.....18-7351 to be exact.......The things you can learn if you just ask...
