i changed the water pump
deagle
put the lower unit back in and it wont shift to neutral its just in forward
Laddies
Banned
Re: i changed the water pump
You need to drop the unit put it and the engine in rev. gear and reinstall the shift shaft turned on you while the unit was out--Bob
deagle
t took the unit out threw the engine in reverse, so now i reinstall the shift shaft turned on you can you explain exactly how i would appreciate it thanks
Laddies
Banned
Take a pair of pliers and turn the shaft on the unit till you get it in rev. gear that is when the prop will not turn clockwise without turning the driveshaft the reinstall the unit and the upper and lower shaft should be indexed properly
