t took the unit out threw the engine in reverse, so now i reinstall the shift shaft turned on you can you explain exactly how i would appreciate it thanks
Take a pair of pliers and turn the shaft on the unit till you get it in rev. gear that is when the prop will not turn clockwise without turning the driveshaft the reinstall the unit and the upper and lower shaft should be indexed properly
