Bullie
Thread starter- Joined
- Dec 20, 2014
- 300
Or, more stupid than is usual. I recently purchased an Evinrude 6012E. I got a pretty good deal on it at $80 I thought. It needs paint badly on the leg and lower engine and the cowl will need some fiberglass work. I polished and set the points, installed a carb kit, a new impeller, removed and repaced the ORIGINAL spark plugs, removed the prop to find that there was no shear pin, etc. Anyway, a friend showed up and in my haste to show him my little find I dropped it in the tank and started it up, the bad part is that I had not replaced the LU gear oil or the plugs and washers. I ran it about 4 or 5 minutes only cycling into forward and reverse a couple of times.
How bad did I screw up and what do I need to do?
I was toying with the idea of spraying some WD-40 into the LU but decided against that. I am now thinking about filling it up with gear lube as normal, running it a little while and then draining it again. What do you guys think?
