Hydroracer
Thread starter- Joined
- Aug 3, 2021
- 3
A friend of mine sent me his 1980 Larson, it has a belly tank in it. The problem is, he just had the floor replaced, and the tank cleaned, and now past 2000RPM's the 470 MerCruiser feels like it runs out of fuel. Pull the throttle back, and it catches and runs, but sometimes dies. He told me about the tank after I went through the carb, and replaced the fuel pump as it failed the tests. It still runs out of fuel. My question is, I look at the tank, and I see two 1/4 pipe "pickups" (I've never seen this before) One looks like it's a welded bunghole, while the other is on a plate with screws around it. Nothing else. The anti-siphon valve is in the one that is just a 1/4 pipe fitting. Which of these two is the real fuel tank pickup? Thanks in advance.
