I found the HIN, now what does it mean?
Unlockme
:D First, Thanks for the great posts in answer to my first question, I found the HIN #, its on the transom on the stern side of the out drive. It is molded into the hull and is partially covered by a mount bolted over the last 3 digits. What I need to know now is how do I find out the year of manufacture of the boat? The Hin # is (as much as I can read) FSJNC209C***. I know the FSJ means Citation Boats in So. Carolina, but what year and other info can be learned from this number? I asume the last 3 digits would be the series of hull manufactured that year, like in a Car's VIN #. And I will try the DMV to locate the owner, Thanks again.
flashback
Re: I found the HIN, now what does it mean?
most manufacturer's will use the last 2 digits for the year model......
Boatin Bob
Here is a site that gives some info on the HIN, seems like it could be a little different if the boat was built prior to 1984. HIN Site
D
DJ
Guest
The last two digits are the year. Bummer!<br /><br />Perhaps the builder can help you out with what you have.<br /><br />Good luck.
