Zraden
Thread starter- Joined
- Mar 19, 2013
- 42
Hello all
Not sure if this is the right section to post this but here it goes.
New to the board and figured I would just jump in to things.
I bought a 1990 Campion 185 Allente with a 4.3 merc engine and leg for which I though was a good deal...Dam was I wrong.:facepalm: We finally got in to it over the weekend and what a disappointment.
We hooked up the muffs and started the engine. Sadly ... water was leaking everywhere.
The manifolds are cracked on both sides. Looks like the seller stuffed the cracks with putty that held out for the test drive, but not much more then that.
The trim solenoid is toast.
I think the block has a 1 cm crack in it. (cant confirm at this point. Might just be an imperfection)
The boat is yellowed.
The spark plugs were original factory.
The distributor cap is cracked.
The engine is burning so rich, it makes your eyes water.
The boat is very yellowed.
Most decals are chipped and peeling.
The covers are ripped.
The interior is somewhat .. ok
I feel like I'm in over my head on this one but my dad assures me its ok and we will tackle one problem at a time. So.... let the restoration begin. The boat pre inspector clearly sucks and should be fired. But its my boat and my problem now. If I do sell it, I refuse to sell it in the condition its in.
I have ordered new manifolds and gaskets.
Buying a new solenoid tomorrow.
Dropping the covers off to an upholstery shop tomorrow for repair.
Bought new plugs.
Having a hard time finding a distributor cap and rotor.
Want a carb rebuild kit but cant find numbers to order one. Its a Rockford 2bbl quadrajet carb if anyone can point me
in the right direction?
Hopefully a good tune up and new parts will get it running right again which
brings me to the hull.
We want to strip the boat to the gel coat pulling off all decals and
try to restore the original white to the boat before applying new ones.
Is there anyway better then another to restore the boats white shell with out stripping it
down to a bare hull?
As for the upholstery, its in pretty good shape but I hate the pink stripes in the seats and arm rests.
Do vinyl dyes work or will someone end up with dye bleed on there suit and skin?
Can you dye and seal effectively? I have done some reading on the subject with mixed reviews.
some say it worked great, others said sunscreen caused it to bleed. Any suggestions or personal
experiences with dyes?
Sorry for the 1000 questions. Just so much on my mind to restore this boat to its former
and boating season is right around the corner :blue:
Bought new plugs.
