I have a 1982 mercruiser140i/o no spark
Bt Doctur
Re: I have a 1982 mercruiser140i/o no spark
Safety lanyard switch
bad ign switch
battery stolen
oxidized points
bad coil
no voltage to coil
The list is endless, can you tell us what you have tried so far?
solar7647
We are going to need a little more info to help. Is it no spark at the plugs, distributor, coil? Have you done any trouble shooting? Do you have a manual? Did it happen all of a sudden? Is this the first its been started this year?
Stuf like that
Brianh74
safety lanyard switch
bad ign switch
battery stolen
oxidized points
bad coil
no voltage to coil
the list is endless, can you tell us what you have tried so far?
tried another coil, new cap and rotor new baterry
Bt Doctur
Is there 12V at the + side of the coil with the key in the "ON" position
Are the points installed properly and gap set
Brianh74
we are going to need a little more info to help. Is it no spark at the plugs, distributor, coil? Have you done any trouble shooting? Do you have a manual? Did it happen all of a sudden? Is this the first its been started this year?
Stuf like that
no spark at first plug, and yes the boat was running this year i have no manual
Don S
Manual #13 is for 90 to 97 models. BT likes to use any ole manual he has laying around. For your 1982 engine, the proper service manual is #3 for the engine and #4 for the outdrive. Download them here.
http://forums.iboats.com/showthread.php?t=251571
Brianh74
CHECKED IT OUT TURN KEY TO ON POSITIONtook volt meter across coil and only reading 4 volts why not 12 volts?
solar7647
Proper reading is 4-9v. In your reply to my qestion from before you said no spark at plug 1, so your getting spark on the others?
If it is only the one plug, wire or plug is most likly the issue.
Brianh74
only checked the first plug out first should i try the others?
solar7647
Yes, if you are not getting any spark at any:
1) remove wire from center of distributor that goes to coil, place it against the block for good ground and have someone crank the motor.
: If you get spark from the coil wire the issue is in the distributor
: if no spark from the wire remove the gray wire from the negative side of coil and try again
: if you get spark after the gray wire is removed the issue is a shorted tachometer
: if still no spark more trouble shooting needed
Try this and let us know.
cbauman79
Follow the sugestions here and you'll eventually find the problem. If you are getting spark from the coil then you should replace the condensor and points. Ta was my problem.
Brianh74
thanks all people here i got my boat up and running changed fuel filter,emptied waterseperator, reset pionts changed cap and rotor and condenser and some fuel stabilizer and fired right up off to lake tomorrow i go for a test run yeppie
