I have a 1989 mercruser tops out at 3000 rpm
dmiles452
I have a 1989 mercruser 350 cu in GM that will not go above 3000 rpm. It gets the boat up on plane but 3000 rpm is all it will do.
Scott06
would also check fuel supply and timing including total advance.
dave8311
Has this engine/drive/prop combination ever reached the proper rpm?
Scott06
Where should total advance be? Fuel supply is good
Not sure if you have a thunderbolt ignition or earlier points... If TB the module usually will say V8-22 or V8-24 the 22 or 24 or whatever is on there is the degrees of advance added to intial timing.
As a rule of thumb would think 28-32 total by like 2800-3k rpm should at least be between the ditches.
If you are not advancing due to module or earlier centrifugal advance getting hung up you wont make power
Also might check spark strength with a spark gap tester
Engine was rebuilt 3 years ago and only has about 50 hours on it
What are the compression numbers today?
How old is the fuel?
TB IV or points? If points, when did you service them last
kenny nunez
Make sure that the choke linkage secondary “lock out” on the carburetor is allowing the secondary air valve to open. With the flame arrestor removed hold the choke butterfly open and try to push open the air valve.
Which carburetor do you have, Rodchester or Weber/Edelbrock?
dave8311
What parts were changed or service was done just before the maximum rpm dropped from 4500 to 3000?
dmiles452
I dont know about compression numbers, I have not checked that. The fuel is 3 months old and it has TB ignition with module replaced at end of last year.
kenny nunez
It appears that you have fuel injection. There is a switch on the shift linkage that prevents the engine from high RPM if the drive is not fully engaged. This switch needs to be checked.
dmiles452
No FI, carter 4 barrel carb
