ShoalSurvivor
Thread starter- Joined
- Aug 1, 2012
- 333
it's a 1971 Glasstron with a 1985 Force 85, kept in garage and was started about 3-4 months ago.
It was really well taken care of. Seems to be in great shape, and I expect it should run. I can't afford to put a lot of cash into this, but would love to take my kids out on the water.
the key was lost, so I had to put in a new ignition switch. I put in new plugs, got some fresh gas and premixed it.
The battery is dead. I used jumper cables to from my Expedition, and it powered accessories and the starter turned. Not enought to start, but it turned a few times.
Q1) Should that be enough power, or does the boat battery delivery more power? I don't want to replace a battery if there are other problems
Q2) Should the starter spin steadily, or will it react to compression in the engine? This one does a whhiiirl, whhiiirrrl pattern. It pops up and trys to spin the flywheel, but cant get enough spin going. Is it likely a starter motor? Should I be able to start this manually with a rope?
Q3) How does the shifter/throttle work. There is a red finger lever at the top of the throttle handle that lifts a metal connector off a pin. That seems to be needed to engage the gears, but I don't know. There is also a little rubber button in the center of the where the throttle arm attaches to the unit. What is that for?
Q4) It only trys to start when the lever is in Nuetral, but I've read that I'm supposed to throttle up to start...so how do I do that?
I'm generally rather handy and mechanical, but don't have a lot of experience with boats.
Thanks for your help!!
Michael
Michael
