I need a replacement prop but serial number does not match
Drewzr14
Hello all,
I want a budget replacement prop for my motor but I can't find a match using the serial number. The number on the prop is 48-73136-13. I am not sure but I am thinking this is a 10 3/8 x 13? If so, do I just find another prop that is 10 3/8 x 13 or do I need to know anything else for it to fit properly?
Appreciate your help!
~Drew
steelespike
Re: I need a replacement prop but serial number does not match
Welcome,
Go to the prop store page and look up 13" props for your motor. A 13" prop of approximately 10 3/8" will work fine.
Diameter is a secondary consideration. A Solas Amita or Rubex are the same prop,the( Rubex has a removable hub) they have a good successful reputation.
If you're happy with your performance stick with the same pitch.
If you think you need to change; answer the Qs in the stickys at the top of the prop forum.
Drewzr14
Thanks for the reply steelespike,
The problem is I have to find a prop using the the serial number (on the prop) as no one has been able to figure out what year motor I have. I'd hate to order something that didn't fit.
Prop number: 48-73136-13
Mariner 40hp (Japan)
Motor number: 40BE 676 B L 403233
airshot
Is it the original prop? If so a yamaha dealer should be able to look that up. Also look under the various manufacturers for that number, some years back I had a similiar situation and found my prop number under the "michigan wheel" manufacturers website.
Drewzr14
Thank you sir, I will give it a go..
