Re: I need an IE7 desk top icon
Ok, here is the latest deal. At first I was a little mystified, now I am a lot mystified.
I uninstalled IE in add/remove programs. I went back to Windows Explirer and IE was still listed under Programs. I expanded it and sent the iexplore.exe to the desktop as a shortcut. I clicked on the shortcut and IE opened up.
I then downloaded the new IE7. The shortcut no longer worked (as before). I uninstalled IE again and went to the .exe, in Program Files, and it worked again.
After you said that after uninstall, it reverts to IE6. So I checked under Help and sure enough, it is IE6 that is opening up.
When I downloaded IE7 over it, all the same happens as described b4.
Now that IE6 is operational again, I will go see if I can uninstall it.
This is goofy!
EDIT: I went to Add/remove programs and IE no longer shows up as an uninstallable program, yet my IE6 Big E shortcuts still work?????
This is goofy!
