Hey,
So Im new to this but have been tryin to read other fourms to figure out what my problem is. I have a 1998 24' Conquest with a 5.7L merc crusier motor. So I had just got done finishing putting new exhaust manifold gaskets on and a new carb (no water in motor problem prior to this, so I think although last time I took it out it seemed like it got a little warm) anyway I fire it up fine in the driveway runs good.. put the hose on it and starter makes nasty noise occasionally but still starts, then get out on the water turn it off then back on 3 times for just moving around and the fourth time starter just grinded up the fly wheel (its still ok though thank god)
and wouldnt turnover the motor so I got towed in, I pulled out the plugs and there was water in each cylinder with water pouring out of some cleaned it all out drained about 2 quarts of pure water from the oil. Then turned it over by hand no problem (no funny noises) then turned it over with starter still ok. but water keeps coming out of cylinder two (which has 0 compression?). Then I did a compression test on the whole motor and this is what I got -
1.158 psi /// 2. 0 psi /// 3. 150 psi ///4. 160 psi /// 5.160 psi /// 6. 125 psi ///
7.140 psi /// 150 psi
Some please help, could it be the manifolds or risers? head gaskets? It wasnt this bad before did the manifold gaskets and carb?
