H@ystack
Thread starter- Joined
- Apr 5, 2015
- 101
Hey all. I have a 2016 Carolina skiff jvx 18. I fully grasp how to run batteries in series to get 24 volts, here is where I am stuck though. .
The boat is prewired. It has 2 sets of wires. Battery 1 red and black and battery 2 red and black. I tried running them in a series. With a jumper but that didn't seem to work with this plug. I tested the voltage at the connections where they attach to the plug and that was 24 volts but that did not compute out the other side correctly.
I think I'm using these pre-wired wires incorrectly.
I had battery 2 wires taped up and put away while I used battery 1 cables to attach to my batteries in a series. Positive off battery 1and negative off battery 2 with the jumper in between. Thesee were all done with the "battery 1 cables"
Now I started thinking , maybe the switch/plug is designed to know when you have battery one and battery 2 set up separately it will relay the series within the receptacle?
I don't know. I can't find anyone that grasps the 2 sets of wires and how they correlate.
The trolling motor is running now but pretty sure it's only pulling 12 volts. I have battery one connected and battery 2 connected separately.
