FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I am not aware of any like the Johnson red book but they are close cousins anyway...cowl or color changes mostly functionnalities are pretty much the same..
part#s may differ being build in US and Canada FR on AOMCI would know or Racerone here.
parts listings are available for both
you should visit AOMCI ask a member forum if you haven't already
What issue is there with orientation of the magplate.-----In my opinion you can look at it and say ---" this is how it fits "-----As it only fits one way !
are we tallking brass swivel ring under the mag plate screw holes not lining up...??
simple... take a sishkabob stick and push it down in a bolt hole till you feel the brass ring is lined up at least with 1 hole and the stick goes all the way down there.
The 3 other bolts holes may not be lined up ...being simply off-set so if all other 3 bolts holes are NOT lined up rotate the base ring and reinsert the wood pick till you see all the 3 other holes lined up.
Insert one bolt to secure the mag plate to the brass ring . Remove the pick and finish insering the 3 other bolts.
I Have a couple of these motors.-----Worked on a lot of them.-------It can only fit one way.----The brass ring has nothing to do with how the magplate is installed.
