I noticed oil/gas around my outdrive yesterday.
johndavidross
I went out to my well yesterday and noticed some gas or oil coloring around my outdrive when I tilted it up. I can't tell where it is coming from. Any first step suggestions in finding the culprit?
81 Checkmate
Re: I noticed oil/gas around my outdrive yesterday.
Pull the boat ota the water and look see.
Next drain the outdrive lube and check for water. If water then pressure test the drive. Don has a sticky post on this at the top of the forums.
That's were id start.
Good luck!
