I/O (Sterndrive) Conversion to Outboards
tpenfield
yeah the new owners of our house stopped by today to give us a hug. We left them lots of useful stuff we just don't need at the new house and like you marketplace is a drain of the soul. We could, and did, and still are, donating lots of stuff but we set them up for success.
is your dash tilted or have i had too much to drink today?
Propped up on one side to get a few fasteners out.
tpenfield
I tried to get the side panel off, which would give me full access to the rigging. Got it all loosened up, but the wet bar was in the way and would require a whole bunch of work to move it . . . :rolleyes::poop:
tpenfield
Bolts are done . . .
I got the longer bolts and finished off the bolts
I had 'AI' show as all painted white . . .
Looks OK.
Next steps are the scarf joints on the outside.
Lou C
ethanol is the devil for marine engines
just had 30 gallons pumped out of my tank due to having to use that!
yeah some people have no problems, neither did I till last year.....I learned from that, to run it on the outboard tank BEFORE rebuilding carbs and replacing points, lol.
tpenfield
Removing the Mercruiser wiring and controls . . .
It is a bit mind boggling to see the amount of electronic 'stuff' and wiring that goes along with these 'current day' engines. I have spent the past few days taking it all out.
Helm station carnage . . .
The Mercruiser cables were foamed-in to a passage way along with the rest of the wiring.
I had to remove the side panels along the starboard side to get decent access. Of course the helm seat/wet bar assembly had to be moved to provide clearance. :rolleyes:
I suppose I should keep these panels off since the re-power shop will need similar access.
I could never have loosened these cable without taking the side panels off.
Here is all the stuff that was behind the helm station . . . Mercruiser electronic spaghetti . . .
I did end up cutting a few power-related wires, because the ends were buried in the electrical boxes.
I also 'think' I found the cause of one of my electrical gremlins . . . The Port engine clean power cable appeared to have come loose at the main power connection. :unsure:
Ted, you realize there is about 400# of wiring, actuators, etc there
Willyclay
It is usually the simple stuff. Hang in there, the "finish line" is so close now. Good luck with your great project!
tpenfield
I'm back from my travels to several places. So, I am getting back to work to finish things up.
Scarf joints on the sides and top plate . . .
I also have the 4 access ports cut out for the deck plates. These will serve as installation access since internal access all the way back to the new transom is not very good.
I ran out of fiberglass resin & putty . . . So, that will be a Friday run. Since I don't need much more putty (1/2 gallon), I plan on mixing my own from the VE resin.
