Volvo Penta is just the stern drive. The motors are still GM.
ezmobee said:There is just simply no friggin' way that an outboard is going to cost you more in repairs/maintenance over it's lifespan than an I/O.
Only maintenance difference that's been apparent to me is a $100 set of bellows on the I/O once every 5 years. I/O oil changes vs pre-mix oil is probably about a wash. Lower unit oil all needs changing the same.
Much older Volvo Pentas have Volvo motors, though. Anyone know when VP started using Ford/GM power, exclusively?
My experience has been the exact opposite. Maybe it's different with the 4-stroke powerheads now, but I can't imagine how. Assuming they last just as long as an I/O, they have to be much more expensive to rebuild.
But the pressure lubricated GM engine in the I/O outlasts a 2-stroke powerhead by at least a factor of 2 to 1, and the 2-stroke outboard powerhead is at least twice as expensive to replace (a rebuilt 260HP 5.7L costs $1600 shipped to your house, what's a rebuilt 250HP 2-stroke cost?) which more than offsets the bellows maintenance cost. I have no idea how much a rebuilt 250HP 4-stroke outboard powerhead is, but I bet it's not cheap!!!
Volvo used Volvo 4 cylinder and inline 6 cylinder engines. The V6 and V8 Volvo's have always been Chevy except for a 2 year run of Ford (76-77) and that was it until 1993. Then things changed.Much older Volvo Pentas have Volvo motors, though.
In 1994 when Volvo and OMC went into the joint venture, OMC brought along the Ford V8's again, but they only lasted through 96. Then Ford was dropped from the linup completely. In 98 OMC sold out completely to Volvo.Anyone know when VP started using Ford/GM power, exclusively?
In the 3 years I've owned my 89 regal, all I've done to it aside from plugs/distributor/oil/filters, is the bellows and shift cable.Yep, on $5k boats I'm sure that's all they'll need! Silly me.![]()
