I put in 36.5 ounces of drive oil, supposed to be 32 oz?
egleas84
Is this normal? or am I loosing drive oil into a bellow? It isn't visibly leaking anywhere (like from the exhaust or or water intake). If it's leaking into a bellow what should keep the drive oil from getting into one of the bellows?
If that's the case other than running out of drive oil is that specifically dangerous for the power package?
StevenT
Re: I put in 36.5 ounces of drive oil, supposed to be 32 oz?
Thats about right for a Mercruiser Aplha. It takes a little more than a quart to fill.
FreeBeeTony
Did it come up to the vent hole?
egleas84
Yes it did. :)
FreeBeeTony
Probably fine then.............
Ayuh,... Whoever told ya it takes a Quart, is Wrong...
It takes slightly over a quart...
