iamwill1973
- Joined
- Jul 15, 2012
- 53
Went out on a new to me boat and it kept cutting off on me was the 4th or 5th going out and had never had a problem with this. It kept recranking and I would go a little ways then it would cut off again. When I got it trailered I opened the cowl, ummediately noticed the oil tank was empty. Right at the dock I noticed the tinging noise in the engine. I didnt run it long without the oil but there is that noise. I know that the engine will usually seize or never run again without a complete rebuild. But... I took it out again after refilling the oil tank and it kind of sounded ok, not as loud, same speed was obtained and maintained and power was about the same no change I could tell. Anyway my question is how to tell if you just should not run it anymore? It is a 1996 60hp mariner elpto 2 cycle engine. I am thinking it ruined the rod bearings and continued running will throw said bearings parts throughout the engine ruining more then themselves? I really do not know anything about motors much less boat motors. Should I run it until it dies or what? A mechanic said it would have to be completely rebuilt $1800 but if the bearings are just bad why cant they just replace them and go on? If it runs it has compression and the rings should be fine right?:facepalm::facepalm::facepalm:
