Silver Eagle
- Joined
- Mar 16, 2010
- 852
Friday while I was outside with nothing to do I decided to play with my pontoon boat. Last week I had cut some Diamond plating to wrap around the rear corner's of the boat. Well here's where
I Screwed up. I had four of the holes drilled into the sheet metal and I had everything level when I drilled to deep and hit the gas tank.I drilled a 3/16th inch hole into the tank. Luckly I only had a few gallons of gas in the tank and I was in a shady spot I had the garden hose handy so I just sprayed water on every thing until It stopped running.Then I drilled a hole big enough to put a sheat metal screw into the hole with some sealer on the threads.It was one of those self taping with a rubber washer and a cover to hold the washer in place. I tightened it down real good and yesterday I got some plastic steal and covered the screw all over with it. I tried to remove the tank on Saturday but it's in there so tight it wouldn't move. Any Idea's how to make sure the tank won't leak. I can cut the sheat metal around the hole because I still have the Diamond plating to cover it up any way.
