Damifudo
Thread starter- Joined
- Sep 14, 2009
- 277
Here is my issue. The other day when pulling out from the dock in reverse the gears where clunking like crazy in reverse. It has slowly been getting a little worse but never too bad it always goes in reverse. Forward has always been very smooth. I removed the cover and removed the shift cable and shifted into forward and reverse very smoothly. Looks into gear great by hand. I drained the fresh oil I put in this fall and it still looks new. I have had the boat out twice this season.
I then centered the controler into neutral with the thumb wheel. If I adjust it to get a good reverse I loose forward and if I get a good forward I loose reverse. When I get it perfectly centered I loose both forward and reverse unless I push the shifter by hand. When I do I can get the cables to move another half inch either way and get a solid forward or reverse. All this with the engine not running on dry land.
Me being an average Joe thinks the cable is the issue. I repowered the boat 2 years ago and the cables have always worked fine even though they were mean for a larger boat. The have a big loop along the side of the boat so I am guessing what I have gotten away with for two years is now catching up and pitting me in the butt. My plan is to buy new cables. We opened the control box and everything inside looks good.
Anyone have opinions?
