I have a 78 Mercruiser Sterndrive and recently pulled the outdrive to change the bellows and gimble bearing.
I had a novice assistant put the boat in forward gear and I tried to pull the outdrive. It would come part way off, but not all the way off. He confirmed it was in forward gear so I tried harder to pull it off. I have read that they sometimes get stuck so I put a slide hammer on the top of the drive(Pre-Alpha lift hole) and tried to break if free W/O success.
I then checked the shifter and found that the control lever was in forward, but it was in the "throttle only position". I put it in forward gear and got the drive off. My fault for assuming my helper knew how the control operated.
I have replaced the gimble bearing and bellows and reassembled the drive. When I put the drive back on, I noticed that the cable seemed to be sticking AFT more than it had when I had it off previously. It will now shift into forward, but will not shift into reverse unless I manually turn the shift shaft on the outdrive. If shifted fine before I started working on it.
The lower shift cable seems to slide freely and I have attempted to adjust it, but so far(ran out of time) have not been able to adjust it to get it to work properly.
What did I probably damage when I tried to force the drive off while in neutral?
Is it probably just the lower shift cable or might something else also be damaged? If so, what?
Could this have damaged any parts inside the lower drive unit? If so, what?
Is this probably something that I can adjust out, or will parts need to be replaced? If so, what?
Thanks, Joel
Thanks, Joel
