I want to fix stress cracks in the gel coat, what's the best product?
UtahFourWinn
IMAG0261.jpgIMAG0263.jpgHere are some pics. I also will remove/replace rub rail. Suggestions on that appreciated too!
Yacht Dr.
Re: I want to fix stress cracks in the gel coat, what's the best product?
Hello Utah..welcom to Iboats !! :)
Your damage is glass..not filler ..
You are going to have to grind and lay some mat on that hull/deck area .. ( Resin and mat ).
YD.
UtahFourWinn
Thank you! I'm a new boat owner. (Last year) The previous owner beat the Crap out of this boat. Buying used boats sure is a good way to jump in with both feet. Ugh!! This forum has been very helpful. I have been looking up things for several months now.
The small chunks are from a broken strap flapping on the back of swimdeck last month. The damage on the bow nose seems to be the worst. Do you think the same procedure is required on all 3? There are actually a few more areas over the boat too.
Thanks
Yacht Dr.
Nope..the nose is a glass repair ( normally fixed with just mat and poly resin ) ..
Your last pic on the char line should be just gelpaste and spot spray ..
YD.
