Re: I want to take a shotgun to my outboard
WHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOO<br />YIPYIPYIPYIPYIPYIP YEEEHAWWWWWWWWWWWWWWWW<br />Wacked the top of the cav plate and the stud on the front a bit (using a hammer on a piece of 2X4)... crack got bigger.... wedged a prybar in there, opened up a little more! I had to get my wife out there to lift the motor while I held the lower so I could clear the driveshaft out of the bottom. The only thing that hung up was the black rubber hose, I think it's the speedo hose. This line is really odd, looks like rubber line but you can't squeeze it, it's hard like plastic line... I wonder if it dry rotted or something. Anyway now I can tackle the water pump tomorrow. I'm wondering if I should just replace the whole pump while the lower unit is off.<br />The lower unit is hard to handle... I am going to build a wooden bracket to hold it upright while I work on it (I had the prop on it and left the gear oil in it so it's a bit unwieldy...)<br /><br />THANKS TO EVERYONE WHO PUT IN THEIR 2 CENTS AND GAVE TIPS, HINTS, AND ENCOURAGEMENT!<br /><br />By the way, this thing looks great inside, looks like the previous owner kept real good care of it. All the nuts/bolts had antiseize, the shafts had lubrication on the splines, everything looked nice and new in there.<br /><br />By the way, what kind of grease should I (relubricate) the shaft ends with (shift shaft and drive shaft)?? I have some waterproof bearning grease "for boat trailer bearings". Is that good?<br /><br />THANKS!!
