Re: I was wrong, found milky oil leaking now in my merc 3.0. Now what is going on!?!?
OK, here are compression results... I don't know if this is the proper numbering sequence to the cylinders, but I called the cylinder closest to the bow of the boat #1 and counted back towards the stern being #4. I actually did the test three times. I don't have an oil can, so I thought I couldn't really do a "wet" test, because I didn't have a good way to get oil into the cylinders without dumping more than I needed and spilling all over the place. Halfway through the second test I thought of using a straw to suck up a little oil into it, and then let it run into the spark plug opening by releasing the seal of my tongue.
First dry test: 112 - 119 - 114 - 128
Second dry test: 125 - 124 - 127 - 130
Wet test: 131 - 136 - 141 - 142
When I ran the engine to warm it up, I noticed a few things. First, and most important, the oil in the engine looks pretty clean after two full flushes. Two minutes into the engine running at idle, I noticed a small puddle of clean oil collected in the housing of the flywheel. I let it run for another 10 minutes or so and it didn't really seem to change, and I didn't see any oil anywhere else. I then increased the rpms to about 1500 for a couple minutes, and didn't see a change, the increased to 3000 for about 1 minute. At 3000 is where I found the contaminated oil leaking earlier in the post. This time, I didn't see anything.
Anyone see something I missed, or am I good to do my final oil change here, putting in the "good stuff" and consider myself lucky? Of course, sometime very soon I need to get the auto bilge installed
