halas
- Joined
- Jan 27, 2009
- 347
Re: I would appreciate help with my Aluminum hull prep and refinish steps
Shiny new aluminum should be etched because it is too smooth for paint to adhere. Oxidized dull aluminum surface will however take paints without etching due to the porous surface already existing.
I agree with that 100%. Also would like to add that the oxidation formed on the aluminum can be good base for paints. Lots of time the old chalky paint is confused with aluminum oxidation. The old chalky paint should be removed before painting but not necessary the actual aluminum oxide.I always thought that the best finish for aluminum in terms of corrosion protection is the natural oxides that form on bare aluminum. Its when saltwater gets under paint through chips or scratches that saltwater gets trapped, and with the lack of oxygen, starts eating the aluminum away. I do not boat in saltwater now, but when I was in the Coast Guard, I boated on both the Great Lakes and the Gulf of Mexico. The 41' UTB that has been the standard workhorse in the Coast Guard for 30 some years is aluminum hulled. Here in the Great lakes, they are painted white. In saltwater environments (and they sit in saltwater as opposed to being trailered), the aluminum is left bare. Also, all of the newer CG boats that are aluminum, i.e. the 25' and the 45', etc are left bare. So, if your primary reason for painting is corrosion protection, IMHO- skip it. If you desire paint for its appearance, then others can help you, as I am no expert.
