I would like to introduce myself, and talk about my rebuild.
jcsftwre
Re: I would like to introduce myself, and talk about my rebuild.
I done the tug test on the FG that was sticking up it is stuck and not moving. The only thing I can pull up are the few fibers that are not laying down. They pull up but everything else is part of the hull now.
erikgreen
Super! Good job on the glassing.
Yeah, the original stringer structure sure looked interesting. Kinda like it was a cheap assembly rather than lack of resin. I'd guess they sprayed the stringers with a chopper gun before setting the deck on top of it rather than using putty or glue.
Interesting.
Erik
Mark_VTfisherman
From the author, a marine surveyor;
"Example of hard spot caused by improper stringer design and installation. Bottom hinges around hard edge of stringer wood core. At right, wood core is elevated by a soft material so that it does not touch the hull skin and the load is bourn by the more flexible tabbing. "
Heres the link for more reading on hull failures,
http://www.yachtsurvey.com/HullFailP2.htm
Thank you! I have read a lot over the years as far as building boats, but this article confirmed a lot of things I sort of "knew" AND I learned some new stuff. I have used certain methods because you're "supposed to do it that way" but I have a better understanding of the why in some cases. I now feel a little superior to those who have poo-pooed me as being too anal about some "details."
Because of the scale of things, the smaller boats (10 feet to 21 feet-ish) I work on won't (or shouldn't) have some of the issues to the degree he writes about. However, the common sense of proper fillets and attention to the overall engineering and torsional rigidity of a hull by bulkheads, knees, and intentionally placed lockers is really affirmed in those pages.
Thanks again.
jonesg
Check out these boat reviews,
http://www.yachtsurvey.com/boatreviews/indexboatreview.htm
Not the usual fluff seen in magazine reviews.
The shamrock 26 is highly prized around here, the review rips it good.
And he's right.
Much of what we do ourselves comes out better than the original factory.
For bedding stringers to hull, leave the chopped fiber out, its not supposed to be brittle.
My sense is...
Regular formula peanut butter type putty is good.
It doesn't form the same type of hard point as a vertical plywood stringer, glassed all around.
An 8 foot vertical ply will not bend fore and aft.
An 8 foot bead of putty will flex.
It just needs a spacer to get it off the hull.
erikgreen
Since we're discussing hard spots a little, I thought I'd add some info here. Boy, am I getting long-winded in my old age. :)
Here's some questions and answers about it:
* What's a "hard spot"?
A "hard spot" is a place where a fiberglass hull flexes in response to stresses unevenly with respect to the surrounding glass. IE, the supporting structure does not permit the hull to give, so the effect is similar to placing a coin on a cushion, putting a sheet of paper over it, and pressing down on it. The coin doesn't give, so the paper is embossed with a circle where the coin lays.
* Why are they bad?
Because uneven flexing of cured fiberglass usually creates even greater stress at the interface between the flex sections and non flex sections... remember the outline of the coin? That usually means the resin at that spot flexes beyond its ability to resist cracking, and it starts to form a crack that weakens the hull. Repeated flexing creates more cracks, and weakens the existing ones. Once the resin cracks it isn't holding the glass in place. Without reinforcing resin, fiberglass has little strength and the hull eventually forms a leak, hole, or fails entirely.
* Can non fiberglass hulls have hard spots?
Sure, but most non fiberglass materials don't crack or break like resin does when flexed, eg. metal or solid wood, so the hard spots don't matter as much. It's still best to avoid creating spots of great stress on the hull for other reasons, of course.
* Can a cored hull have hard spots?
Yes, and in fact this is usually worse than a solid hull having them, because the core is usually water absorbent one way or another, and water getting to it will cause rot and delamination, causing a hull failure sooner than a solid hull, and forcing a larger repair to get all the water out.
* Can stringer wood touch the hull and NOT form a hard spot?
Sure. As long as whatever support structure the hull presses against supports it evenly, no hard spots will be formed, IE the whole hull will flex together.
* But ideally, you shouldn't have wood touch the hull, right?
It's the best way to make sure you don't have hard spots, especially if you're going to stress your hull a lot.
* So what's the best way to keep the wood off the hull?
You don't actually have to keep the wood off the hull so much as you have to make sure it touches evenly. The easiest way to do this is putty the stringers in place... use a poly adhesive to bed the stringers, or putty made from resin, or any other appropriate thixotropic (non flowing) adhesive. Whatever you use, it needs to form a bridge between the hull and the stringer. Since it matches the contour of the stringer on one side and the hull on the other, it transfers force evenly and prevents hard spots.
* What about using foam?
That's the ideal way to keep the stringer off the hull, but it's harder to build. Basically you use a trapezoidal piece of foam (almost any type works, but it must be resin compatible) to suspend the stringer in the air, but in place in the hull. You then glass the stringer in place. The foam stays in the layup, but performs no function after the stringer is glassed in. The fiberglass between the stringer and the hull transfers all the forces of motion from hull to stringer and back very well, and for extreme uses permits more flexure without breakage than any other method. Think of it as similar to the old eastern proverb about an old tree breaking in a strong wind, but a young tree bending and surviving.
There's a variant on this method where you use blocks, clamps, or whatever you like to suspend the stringer in place while you fillet the bottom edge and glass, but this requires more adhesive than other methods.
* Where else can hard spots form?
They can form elsewhere in any place a non yielding item sits directly against the hull. The corner of a fuel tank that's not padded, a frame or bulkhead, basically anywhere there's a spot on the fiberglass that has something non yielding behind it. In non hull glass it doesn't matter as much, since it's not under as much stress as the hull, but hard spots abound.
* Where should I never get hard spots?
There should NEVER be stress cracks is the keel.. on most hulls this is the strongest area, and if this area is stress cracked, something is very, very wrong with the hull. This area of the hull also shouldn't flex except on a microscopic level, since it's supported by most of the rest of the hull, so avoiding wood touching the hull here isn't much of an issue (unless the wood that's there is rotten and not supporting the keel). It's more likely there's a major structural problem with the hull, or there was a high stress single event like a hard stranding. Likewise, the transom on most powerboats should not flex, for many of the same reasons.
* If I have a hard spot that's cracked, can I fix it by grinding out the cracked glass and glassing over it?
Yes, but the hard spot will still be there, and your repair will crack at the least, and might fail catastrophically depending on your repair technique (since it's not part of the original hull). Repairing cracks or holes in ANY piece of fiberglass requires first understanding why the problem is there. Cracks or holes are almost always symptoms of something else, stress on the glass from somewhere, and not fixing that first means you're just doing a cosmetic repair.
* What if I have stress cracks that aren't near a stringer or any other wood?
Look carefully at the crack. Usually it's at the center of the stresses involved, like a line in the center of a fold in paper. A horizontal crack means something squished the glass above and below it vertically somehow, a crack in a corner means usually something tried to "spread" the corner, etc.
As mentioned above, you need to figure out what's causing the crack, or at least what's permitting it to happen. Remember that whoever designed your boat, if they did a good job, knew the stresses that would be placed on it and designed it not to crack, so if it's cracking then either some support member is broken or failing, or you've placed the glass under an unusual amount of stress, something the boat wasn't designed for, like being dropped from a forklift or running aground at 80 knots.
Look for what stiffens and absorbs force for the glass that's cracked. The deck or sole is supported by stringers, which transfer weight from the deck to the hull. The hull bottom is also supported by stringers which transfer force to the rest of the hull, the transom, and deck. The sides of the boat are supported by the bulkheads, top cap, occasionally some molded seating or a cockpit, etc. Sometimes even injected or pourable foam may play a part in support, and when degraded will cease doing that job.
Sometimes you'll see cracks form that are secondary symptoms. Like for example cracks forming around the bolts on a seat pedestal. The pedestal itself might not be at fault, nor the deck under it weak, but your whole deck may be sagging due to a bad stringer, or worse your frames and bulkheads are weak and permitting the hull to "fold" slightly lengthwise.
Finally, you may see cracks that aren't from hard spots or repeated stress, but that don't appear after any obvious incident. For example, a crack around a circular area on a boat top cap, or a large series of cracks around a cleat. Gelcoat is good at hiding cracks since it's a solid color all the way through, so you may not see the problem until dirt collects in the crack. The fix is still the same... figure out what happened, fix the structure, then fix the glass. If you can't figure out what happened, post pics on iboats :)
Take care not to form hard spots in your boat repairs, but don't stress if you find one, you can fix the problem and go on using the boat safely. Just check your hull on a regular basis when you do your other maintenance.
Erik
jonesg
Yeh that makes sense. That would make a good sticky.
MERIT6419
Rick,
nice work you really got things going pretty fast now and looks like your getting good reviews from the experts. I know its hard to read erics ranks cause they are so long. haha but I have not seen him lose an arguement or not be able to articulate himself so all could understand. long posts but great info. Keep the pictures comeing. oh one last thing those fish at the begining are monster wow good catch.
Genonbamagirl
First and foremost - thank you for your service.
Second - damn nice resto brother - you are doing a fine job. Can't wait to see the fish you catch with this one. :D
jcsftwre
Structural integrity of the hull Dec-17-2008
In doing some research on my boat I found an original old add from Chrysler.
I have been trying to find the proper placement for my deck. Meaning where the edge of the plywood should meet the side of the hull. The last person did not have the plywood even extent all the way to the hulls edge. Instead they stopped it about ? way across the bottom of the boat. I think this is one of the reasons there is a problem with this hull being cracked.
Second to that in the photo I posted you can clearly see the seats in the boat should go all the way across from hull side to hull side. When I got the boat that was not there AND I can see in the fiberglass the place that the wood support SOULD have been but was taken out years ago.
Third, in the photo you can see half way between the seats and the motor a brace going up the side of the boat. That was not there either in my boat. At some time someone took that out.
I believe all of these things combined has lead to the hull falling in this boat.
In most photos that I can find the deck should be going to at least the apex of the hull side to the bottom of the boat. In some the deck joins the hull some place up the side from about 1 inch to 8 inches.
one example:
What do you know about the placement of the deck as to where it should meet up to the hull side?
By the way notice my boat cost $415.00 when new?
jcsftwre
Thanks Genonbamagirl :) !
I was hoping this would take only a few months to do but now I can see it will take longer than that. But I still think I should be able to be back out fishing this coming season. I sort of have got into trying to find what this boat looked like when new and trying to make it look as close to that as I can AND with keeping my budget in mind. I have some seats close to the original that come from a Ford F150 that I may modify and use. I know it sounds funny but they are real close to the size and shape needed and best off they are free I already have them. I just need to recover and rework them a little bit.
Rick
jcsftwre
Rick,
I caught those on a Fenwick ultra light rod using two pound test with ? or ? pound leader. :eek: They took about 30 to 40 minutes to bring in and almost spooled my line at least two times each. We where throwing back 24 inchers because they were to small.:D
If you ever plan on going to Alaska I can draw a map right to the place I caught them. I had done that for a guy who did go and he was catching 24 to 28 inch trout.
jcsftwre
Here is something funny, I found some old photos from that fishing trip the other night.
This was my first boat I paid 100 bucks for it. Notice the electrical conduit used for the cover support?
I use to call that my roll cage. :cool:
This is the lake i got the fish from, Lake Louise Alaska http://maps.google.com/maps?q=Lake+Louise+Alaska&rls=com.microsoft:*&ie=UTF-8&oe=UTF-8&rlz=1I7GPEA_enUS291&um=1&sa=X&oi=geocode_result&resnum=1&ct=title
Mark_VTfisherman
Nice...bimini? But hey, if the boat floats, fish it!
Obviously it works: nice fish!
MERIT6419
what happen no update hope your doing ok let us know how the projects coming along
jcsercsa
yea where you been Rick ???? john
PFalcon
More hours spent getting to know a great guy, and watch a great restoration.
Being disabled myself and knowing the challenges, I am impressed!
I hope and Pray that Rick is doing well, and is just offline for awhile taking care of himself.
I know we all wish him well and pray he is fine!
I wonder if "Santa aka CSM Gifter" has a contact number? Maybe someone has more info and can check on him?
PF
redfury
I've emailed him a couple of times in the past since this thread has started. He's a heck of a guy. Talks about his ordeal, but doesn't complain about it.
Don't worry though guys, he has people that check in on him. His sister lives close by. For him, his disability makes it difficult for him to even get out of bed some days, and the new medicines that the doctors were working out with him were only partially effective, but not somuch that he could move forward...probably has taken him a step backwards for a while.
Rick, we are all thinking of you bud! Hope that by the time you get a chance to get back here you've seen some forward progress ( on your boat, and otherwise! ).
