jtcarter
Thread starter- Joined
- Apr 26, 2008
- 226
I traded for a 18 and a half foot hydra sport with a 175 evinrude intruder this spring. It ran fine while it was cool. When it started heating up i started having all kinds of problems.
Heat soak made the most sense and still does. Anyway i've went through the ignition. New pack,stator,coils,wires. Thought rectifier was bad. Got another one today that was off a boat that ran. I've also been all the way through the carbs. Anyway after installing rectifier i took it to the lake. It was hot here today. I made a run up the lake about probably 4 miles. Had no problem. After i shut the motor off is when i have the problem. I restarted it and put it in gear it died. I restarted it,let it idle for awhile and it got up and took off. Ran back down lake to another of my fishing spots and i shut it off again. It did the same thing after i restarted it. I put it in gear tried to accelerate and it quit again. Once again i restarted it let it idle for a couple of minutes and it took off again. I'am trying to replace my runners on my trailer so back at the dock i left the boat setting in the water for about 30 to 45 minutes. When i restarted it to put it on the trailer, you guessed it, it died again and it died everytime i put it in gear. But i didn't let it idle that time because people were waiting on me to get out of their way. I have a manual and about the only thing left that i haven't done is rebuild the vapor seperator, since it has a float its possible its hanging up. My compression is good and the tops of the pistons look good. I'am about at my wits end with this thing. I've spent a boat load of money trying to chase this problem down. I guess it could be this sorry eythanol fuel. I'am going to try and find a service station that sells regular gas.
