ice freeze up
trucker28
Re: ice freeze up
Ok so I came to the conclusion that it is not getting fuel not sure if out of gas or not I will try that first and go from there
I found this by pulling the clear line of the carburetor off and trying to start and got no fuel
alldodge
Re: ice freeze up
I found this by pulling the clear line off the carburetor off and trying to start and got no fuel
The only clear line on the carb comes from the fuel pump diaphragm. If the diaphragm ruptures then you will see fuel in the line, and only then. You should have a metal line going from the fuel filter to the carb.
Since we don't know what kind of engine you have things could change
trucker28
Re: ice freeze up
Lol so wrong line I will pull the steel line and try that and go from there I have a 230 hp I/o merc
