Ideal prop for Q6 Tahoe 5.0 alpha ?
maddog2112
Hello all, I recently purchased a tahoe Q6 with the alpha one 5.0 and am hoping someone out there has figured out the best prop for this boat. I`ll be pulling tubers and skiers with the boat. I currently have the 21 4 blade it came with. I am a novice at this, and I hope you all will forgive me with my lack of technical knowledge on the subject. I`ve had the boat out once so far and top end was 48 on the speedometer, but the boat seemed a little slow to plane, and not great at slower speeds. Thanks for the help.
hwsiii
Re: Ideal prop for Q6 Tahoe 5.0 alpha ?
Mad, welcome to Iboats prop forum and we will try to help you as much as we can, but there is certain information that is needed in order to help you. Working over the internet and not being able to see the boat or prop the question is about makes it much harder to propose a solution to the correct prop that you need, and most people don?t know the make and model of the prop . When we get information in bits and pieces we continually have to look back and forth to try and piece the information together. The following form has all of the information that is needed to help you with your problems in finding the right prop. If you do not know all of the information that is asked for on the form please give us the most information you have available as I have a program I designed to find the right prop for any planing hull boat that needs this information. It requires time to find all this information when we have to look for it and in my defense I expect you to be willing to expend as much effort in finding the right prop as I do. We hope to be able to help you get the best prop we can for your particular uses, and this information is required to do that. It is not as simple to pick the right prop as most people coming to this forum think it is, that is why we ask so many questions, it is for your benefit we ask all these questions.
There are other people who can help you that don?t need this much information, if you would rather wait for them just don?t fill out the information I am requesting. And if you have a stainless steel prop or are changing to one the blade geometry of the prop can make a lot of difference in speed, RPM and the handling characteristics of the boat. Most of my calculations are done assuming an aluminum 3 bladed prop will be used, when changing to a SS or 4 blade prop, or changing within SS props I need to know what you are trying to accomplish.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
