- Joined
- Jul 18, 2011
- 19,160
The survey of my 'new to me' Formula 330SS indicated that there are higher than normal levels of moisture in the bulkheads. I also found water residing in the forward compartment due to a leaking anchor locker, and the associated bulkhead seems to have absorbed a good amount of water. The initial drying out of the bulkhead resulted in some spider cracks appearing on the outside of the hull along the location of the bulkhead. (I assume this was due to shrinkage of the wood core and surrounding fiberglass that occurred, etc)
So far, I have removed the standing water from all the areas where it was present & trapped. (Yes, the PO was probably not aware of the issues)
I should also mention that there is a small crack (4 inches) in the fiberglass along a 'separator' for the starboard side 'sub-stringers' in the engine compartment. (sorry, I don't have any pics of this). I have fed some bleach into the crack to fight any deterioration that may have started. This crack seems to have appeared due to a very small void (1/16") in the glass right at the corner where it intersects the engine mount stringer.
Ideally, I would like to get the water/moisture out of these bulkheads and apply preventative treatments to these areas to fight off rot, etc. The boat is 16 years old and has been in fresh water on a seasonal basis for its entire life. I feel that the boat is at a turning point in that if the water retention is not address now, it will lead to a fair amount of structural rot in a few years time. If I can address it now, then the boat should have good longevity.
So . . . my question to the forum. How might I 'get the water out' of the bulkheads at this stage of the game?
I was thinking of drilling some test holes at the lowest and highest levels of the bulkheads, etc where water has accumulated and then applying heat (like 100+ degrees F) for several days. If need be, I could also allow some Ethylene Glycol (EG Anti-freeze) to soak into the bulkheads through these 'test holes' . . . sort of like 'chemotherapy for boats'.
Do you think this would be a good approach? Anyone else done this sort of thing ? Ideas & suggestions?
Thanks in advance (TIA)
