Identify thru hull fitting
seven up
Re: Identify thru hull fitting
maybe there's some model specific information in your ski deck manual. the thru hull fitting may have a nut on the inside of the transom.
Don S
Still back at the same old game.
1. There is no such boat manufacturer as "Ski/deck"
2. What ever this thing is probably had a year of manufacturer. (Still not given)
3. If there is no manufacturer that you know of, and no year of manufacture, how do you expect anyone to tell you how to get to it.
To be quite honest. I am beginning to think you are a troll. Just looking to stir the pot with unanswerable, questions. Hell, you don't even answer the questions when asked, all you do is yada, yada, yada.
onemarvin
OK seven. Hope they are posted. thanks for the help
HT32BSX115
Howdy,
your best bet here would be to pick up the phone and give them a call!
  1. AMERICA'S DECK BOAT CO
    PO BOX 1041
    GATESVILLE, TX 76528-6041
    254-865-4206
Gore's internet is a beautiful thing!
Cheers,
Rick
onemarvin
Thanks a million. I was not aware they were still in business.
Windykid
you might want to have your hull ID number ready, so as to Identify the model, make, etc....:rolleyes:
onemarvin
I can get no answer at the Gatesville number. It seems to belong to a private party now.
Windykid
Gatesville is local here and I am getting a bussy signal. keep trying, I think you called at lunch time.:) :D
HT32BSX115
You may have a boat (like many) made by a company that is no longer in business.
My Four Winns Liberator has an ice box that drains via a "Thru-hull' in the side.
Your only fix may be to remove the fitting and use marine glass & epoxy to seal up the hole.
This thread should probably be moved to the Boat Restoration and Building section........
Moderator?
Cheers,
Rick
MJ76
I doubt seriously that the boat came from the manufacturer with that fitting there. Never mind that the fitting is way large for an ice chest drain. You can't get very tight on those plastic thru-hulls, and they get brittle with age and can break....easily, potentially sinking your boat. If you replace it, at least get a brass thru-hull that you can seal and tighten. And as I mentioned before, water leaking there may have wicked into the wood in your transom. This could cause you bigger problems. I would recommend having someone check the transom with a moisture meter to determine if any damage has occurred.
