Re: Identity Crisis
Joe, are you looking at TD's motor or the one that whywhyzed posted? There is nothing about TD's motor that looks like a '78 to me, but whywhyzed's Johnson might well be.
Look at the powerhead - it is Johnson green and the paint looks like it is original. That particular shade of green would make it a 1969 or 1970 and I think its a 1970. Also look at the thermostat housing on the head. It's just like the older motor and not at all like the 1978. I'm with FR, this is the 22 CI block.
The flame arrester/filter screen on the carb, however, is off a motor that is a 1971 or later. This is evidenced by the single leg on the bottom. starboard side of it. The 1970 was different and had a pace where both the choke stem and HS jet passed through.
On the exhaust housing of TD's motor, the lower shock mount bracket is rounded, while it is squared on the 1978. The section of the exhaust housing where the water pump assembly is located is also rounded on this motor, while the 1978 is flat on the top.
I still think this motor is a collection of parts, mostly consisting of an Evinrude dating from about 1972 to 1975.
PS: What is curious about this motor, however, is that the hood looks like a 1978 Evinrude 25. This means that the lower cowl section is from a similar year also because the shape of the lower cowl from 1976 and older is different.
