Idiots with JB Weld
300sflyer
Just removed the intake manifold on a friends 1990 Merc 4.3 V6 after finding water in the oil, and here is what I found. Some idiot [likely the previous owner] actually thought he could repair his cracked block with JB Weld.... :eek: Time for a new block.
Re: Idiots with JB Weld
Just removed the intake manifold on a friends 1990 Merc 4.3 V6 after finding water in the oil, and here is what I found. Some idiot actually thought he could repair his cracked block with JB Weld....
Ayuh,... I'd say it worked Perfectly...
It held long enough for yer Bud, to buy it...
300sflyer
Peeled away the JB Weld, and found another surprise. They tried to braze it too... Can't believe someone would go to this much trouble, instead of just replacing the block.
paultjohnson
Curious,,, Did your bud just buy the boat without any of this being disclosed by the previous owner ? i mean, was is a blatant rip-off ?
300sflyer
He bought it about a year and a half ago, and it seemed to run fine then. It has not been used much until recently.
fishrdan
That's a mess, sorry to hear about it.
Some idiot actually thought he could repair his cracked block with JB Weld.... :eek:
Surprised there wasn't a wad of duct tape in there too, just incase the JB failed :facepalm:
Don S
Makes you really want to run out and buy a boat sold "as is" from a private seller doesn't it.
bgc
Ensign
Hello? Duct tape is for fuel lines and electrical system repair...
jeromeb
Wow, That's a real first class brazing job too. :D
300sflyer
Purhaps if I chip away at some of the brazing, I will find some chewing gum in there as well... LOL!
bnicov
See, if the PO had used Duct tape, there would not be a problem. That sucks for your buddy.
Fl_Richard
The JB Weld package states - "Farmer Joe repaired his John deer engine block with a tube of JB saving him a $15,000 dollar repair"
Obviously your guy did it wrong :)
GA_Boater
No wonder it failed! A GM does not a John Deere make. Most obvious misuse of a fine product. And no silicone, a half-hearted repair indeed!
zopperman
So my cracked block is going to leak again... crap...
AZSenza
Depends on what part of the block your trying to fix! Pressurized areas "Not Included"
