Re: Idle adjustment on 60 horse Johnson 3 cyl
Did you blow out the Passages with compressed air? Also, did you set the float level of each Carb.? Number of turns on the screws should be close to each other in an ideal situation. Initial setting for a 60 HP is 2 1/2 Turns out. I would also suggest if you take then off again, get rebuild kits for all of them, as needle seats and other internal parts can become deformed after sitting for a while. They are only about $15.00 Per carb. for the kits. Well worth it! I have a 91' 70 Hp, which is basically the same Motor, so I do have some knowledge of yours. If you need further help, let us know! But I bet if you re-clean the Carbs. and blow out the passages, then install rebuild kit, it will run much better! Good Luck,<br /><br />EDIT: Also, what do you mean in your first post that you advanced your linkage to acheive a higher idle? Do you mean you adjusted the Idle screw or the actual linkage to attain a higher idle? You may need to syncronize your linkage, also. Please respond before you tear it down again!
