idle adjustment?
bcsnare
just replaced the plugs, noticable improvement.
Idle speed is about 1000-1100. where should i start first, idle adjustment, or mixture adjustment?? the mixture is about 1 1/4 per the manual. sounds great, just a little high (i think its supposed to be like 800). the floats and needles are in good shape, and im fairly certain the floats are properly adjusted.
jaybirddog11
Re: idle adjustment?
What year, horsepower and model #? You should be fine adjusting the idle adjustment screw until about 750-800 rpms. Adjust the mixture screw out one full turn out and adjust until properly set. Just my 2 cents
sidenberg
I believe you should be about 800 rpms when in gear at idle speed. If you are at 1000 to 1100 in neutral you will probably be at 800 in gear. To test, tie up to the dock and put it in gear.
bcsnare
87 125hp. thanks...i figured i would have to do it in gear in the water(with a load on it)
jerryjerry05
Air screw out 1 1/8-1/4 turn.I leave them at 1 1/8 seems to work well. Idle in-gear 750-800. Start bring up to temp.Then move away from the dock put in gear and then adjust the idle.J
