Idle adjustment
Bshaw316
Is there and idle adjustment screw on the carburetor of the Mercury 3.0? The motor runs great, just seems to run a little rough at idle, like it needs more fuel.
Bt Doctur
Re: Idle adjustment
Define idle adjustment., idle speed or idle mixture. The last full tune up was when?
Bshaw316
Re: Idle adjustment
I just bought the boat and it was serviced just before season. That my question, is there an idle control screw are in idle air mixture screw that can be adjusted on this motor? I was just wondering if there was something where I could bump the idle up a little bit?
Fastatv
Re: Idle adjustment
Yes, the carb has both, air/fuel adjustment and an idle speed adjustment. Rick
alldodge
Re: Idle adjustment
:welcome: to iboats
How about an engine serial number or at least the year of the boat.
Bshaw316
Re: Idle adjustment
:welcome: to iboats
Captain it is a 2006 Bayliner 175. I don't have serial number but can get it when I get home.
Bshaw316
Re: Idle adjustment
Thanks Rick. I have been looking at videos and reading forums. Say idle should be around 650-700 on warm engine in neutral? Another one I read said around 850-900rpm? It just seems like I have to give more gas to get it to start after warmed up. And I'm sorry I'm a newbie to this but seems like it should just start and run in neutral after warmed up and it doesn't. It starts then stalls. Any pics or diagrams where these adj screws are located?
alldodge
Re: Idle adjustment
Being it's a 2006 I'm pretty sure you don't have a carb, your fuel injected. With that, I would first look at and clean your Idle Air Control (IAC) valve. It is loacted on your throttle body, the thing that looks like a carb
solar7647
Re: Idle adjustment
I believe Merc specifies proper idle RPM is taken n set with the engine at temp and in the water.
Also your idle adj screw will be were the throttle linkage rests, the throttle cable connects to a lever/arm on the carb, that lever/arm rest on a hard stop when your in N, there is a screw there that you can turn in/out that will adjust were that lever/arm comes to stop at. Adjust the screw in to add to idle RPM and turn out to subtract from RPM, 1/4 turns at a time so not to over do it.
The air/fuel mixture needles/screws will be along the base of the carb, you will notice they have a spring that pushes on the head of the screw between the carb body and the screw head. These adjust your air/ fuel ratio, if you turn them in you reduce or lean the mixture if you adjust out you make the mixture richer or increase it. Standard tuneing procedures say to turn the needles all they way in, don't torque down, just gently turn in until they stop, then adjust them out one an a half full turns. Start n run the engine and make 1/4 turns on then until proper RPM is achieved.
I have found in my experience you will get one of two answers to the question of what the proper idle RPM is, one will be with the engine at temp in water in N, the other is with engine running at temp with it just shifted into F.. Meaning shift from N into F then bring you shifter back as far as u can without shifting back into N...so the boat is under loadand moving toward. They will be two very diff RPM values, I have always been told the proper way is to adjust it is under load and the three engines I have worked on have all been 850-900 RPM idle under load. I'm sure someone with more knowledge of your engine will correct me if I'm wrong , just looks to be the standard as far as I have seen
Bshaw316
Re: Idle adjustment
Solar764 thank you so much for the information. I keep the boat up at the lake and will run it and adj as you have said. The boat is awsome but that little minor thing. My family and I look so forward to becoming boat people. Thanks again for all your help.
Fun Times
Re: Idle adjustment
Being an 06 3.0 it will be a carbed engine. It will also be a TKS carb, the air/fuel mix is not legally adjustable. :rolleyes:
You will need to read the TKS service manual number 41 i believe it is to find out how to adjust it. You'll also need a special tool once you remove the cover hidding the air/fuel mixture screw. You'll find the specifications in the manual as well as they are a little different.
Google merc service manual TKS and you should find it online. Good luck.
Bt Doctur
Re: Idle adjustment
And if not. I can burn a copy of the TKS manual.
Bshaw316
Re: Idle adjustment
Thank you everyone for all your input and advice. I'm hitting the lake this weekend and will try the adj.
