idle question
stormy123
got another ? cant get my boat to idle at norm when i get er down blow a 1000 rpm she wants to die now i got new plugs gapped .35 wires cap button points at 19 rebuilt carb takes gas just fine idles great bout 1800 drop er any lower she wants to miss n sputter 84 omc 3.0 does this thing got a esa or something anything that would keep me from getting the right idle motors in good shape no knockin peckin nothing like that got a little valve seal smoke on start up nothin major i havent met an older moter that couldnt get running right but new to boat motors learning that there a little bit different just wondering if there something else i should be looking at appreciate it
Levinz11
Re: idle question
I assume you changed the condenser and rotor as well. What's the timing set at?
stormy123
Re: idle question
not the condenser got the button i always thought that a condenser would just go bad and no havent checked timing yet those are just the main things to get the idle right [correct] i was wondering if there was anything electrical or anything that i didnt no about being new to boats an all
Levinz11
Re: idle question
A tune up kit for that ignition is cheap. Get to it when you can. Set dwell, set timing 4-6 BTDC probably.
Levinz11
Re: idle question
Definitely read the stickies at the top of the OMC forum. Get a manual for your engine/drive (eBay).
airdvr1227
Re: idle question
Something is not right with the idle circuit on the carb you just rebuilt.
