idle setting ?????
travis37
what should my motor (ve175glenc) be idling at? And is 92psi a good compression give or take 5psi ? THANK YOU!!! By the way, this site rocks for info:D:D
HighTrim
Re: idle setting ?????
If all cylinders are within 10 percent of one another, which yours are, all is well.
Regarding the idle, set it to 650 to 750 RPM under load and in gear. If you are on muffs in the driveway, set it to 1100 to 1150, then fine tune it on the water.
