weekendfisher
Thread starter- Joined
- Feb 26, 2010
- 79
Hey guys, today while watching my tacho was i was flushing the motor on muffs at idle i noted that the RPM's sat around 800-900 RPM for the most part but every now and again it would drop too 500 RPM for just a sec and then back up and you can hear the change in the motor for that second.
I put new plugs in a few months back which have only seen about 5 hours of work since then if that... when its in the water it seems the idle is a little low as sometimes in neutral it cuts out but does fire right back up but when under power it goes beautifully regardless of 5 or 25 knots.
just after some advice here is it something to be concerned about or is it as simple as bringing the idle up.
What is the idle supposed to be when out of water for the 50 Johnson 94 model ?
Cheers
Cheers
