Eddie Mullins
- Joined
- Apr 14, 2009
- 38
Ok - new boater, with 1st boat, new to site, and have many questions so please bear with me.
Just got 197? , Bass Buster? boat with 50 hp motor. Console steer. Has lever for gear and for throttle.
Motor cranks right up, idles well. In neutral it can be throttled up and will run well.
Push lever out of neutral and gear engages, boat will move forward at an idle.
Problem - begin to move up the seperate throttle lever and it just dies. It will not throttle up in gear, forward or reverse.
Here is maybe the dumbest question I will hopefully ever ask on here, could I be operating the throttle and gear levers incorrectly some how or could the malfunction be there? SHould the throttle increase as the gear lever is moved forward? Or am I supposed to push the gear lever all the way forward and then bring up the throttle as desired?
I am hoping this is just a carb adjustment? I don't have any kind of manaual for this boat or motor. Any tips on locating a manual for at minimum the motor?
