spacerust
Thread starter- Joined
- Feb 18, 2008
- 190
ok, some good things and some bad. i started to do a link and sync and ended up tinkering with things before i started. originally at WOT i was going only about 24mph. i've been reading the service manual but need to get priority list. i found that at WOT the carbs weren't open all the way, so i adjusted and now it seems like they will at WOT. but...i moved a few adjustments here and there with my newfound confidence and now once i throttle up it doesn't throttle back down. i have to manual move the level down. so here's what i'm thinking...cables(are they shot, they move up but don't seem to go back down when i put the throttle down? i moved the trunnion on it and don't know where they should be), idle adjustment screw(noticed that at idle it wasn't against its stop, moved it but along with other adjustments don't know where it should be as far as screw). i'm assuming i need to start all over. what do i need to adjust first and go down the line? i feel like a took a few steps forward but then took a few steps back. where do i begin?
