idle
bsh21wash
My boat is idling around 1200rpm's this is too high right? How do I adjust look below for boat and engine.
Re: idle
It's Usually done as part of the Tune-Up process,...
As each step in a Tune-Up changes the idle......
Final Adjustment is done with the Idle Adjustment Screw, where the Cable attachs to the Carb.......
Don S
Re: idle
1200 is way to high, should be in the 650 to 700 rpm range. My first question would be WHY is it idling that high? Did it just suddenly start, did you do a tuneup or something?
May be the cable is going bad on you and not allowing the carb to come all the way back. Thing to do there is disconnect the cable and see how it idles
If you look at the linkage on the carb where the cable attaches, down on the base of the carb or on the linkage is a screw that adjusts the speed.
bsh21wash
Re: idle
I havent made any adjustments/tuneups since I bought it from the dealer. I just noticed it yesterday when i was out on the lake. I'll try to figure it out later today. Thanks
