Idler pulley
NYBo
I've been having a problem with my tow vehicle the past several days. The serpentine belt was loose and slipping. After about 5 or 10 seconds of running, power steering and alternator function would return. I figured the tensioner had gone bad. I finally got a chance to diagnose the problem. Below is a picture of the lower idler pulley I removed. photo215544.JPG Think I should replace it?
Grub54891
I think a dab of sticky grease would help it live another minute or so.
MTboatguy
They are not that expensive, and you have it off already, just replace it and have the piece of mind knowing it will not blow apart on you while you are towing. In the mean time, you could pick up a couple of cans of grease and practice playing McGyver!
NYBo
If not for the dust shield (not shown), the belt would have come off for sure. I can't believe I drove it that way for at least 60 miles that way. The belt wasn't even damaged.:facepalm:
NYBo
Oh, yeah, replaced it this morning.
