idles ok
jim kinser
I have a mariner 40c 6e9 515698. Idles good, rev it up and it sounds like it runs out of fuel, I kited the carbs, getting fuel ok, getting fire ok. I subed the fuel line and tank, same thing. Could it be ignition ?
Jacket4life
Re: idles ok
Did you try squeezing the bulb while at higher throttle and see if it picked up?
jim kinser
Re: idles ok
Yes I did, no difference. It's just like you turned off the key at high rpm, then when you cut the throttle it idles ok. Going to check the ignition today with cd77.
jim kinser
Re: idles ok
Anyone know what the secondary should read on the ign coil.
jim kinser
Re: idles ok
Subbed a new coil, no change. Going to try a cdi unit.
