If i have screwed up as bad as i think i have
Fatbs
As i was re-tapping the holes on the flywheel i screwed up and drill all the way through the flywheel and if i have screwed up as bad as i think i have be watching eBay, Craigslist, where ever else i can part out this 1984 force 125
pnwboat
As long as you didn't damage the circular trigger magnet that is around the hole in the flywheel on the under side, you should be OK.
Jiggz
Worst thing is probably replace the flywheel which is really not that bad.
jerryjerry05
Just drilling a couple of holes in the flywheel won't affect the balance that much.
The holes are close to he center and won't affect it.
You'd have to do a bunch of damage to the edge to affect it.
The holes shouldn't line up with anything so you probably didn't hurt anything.
Fatbs
Thank for the hope. But so far with this motor if there is a remote chance i can screw something i can and have done it.I will keep you updated.
