If my Body were a Car
aspeck
If my body were a car, this is the time I would be thinking about trading it in for a newer model.
I've got bumps and dents and scratches in my finish and my paint job is getting a little dull, but that's not the worst of it.
My headlights are out of focus and it's especially hard to see things up close.
My traction is not as graceful as it once was.
I slip and slide and skid and bump into things even in the best of weather.
My whitewalls are stained with varicose veins.
It takes me hours to reach my maximum speed.
My fuel rate burns inefficiently.
But here's the worst of it -- Almost every time I sneeze, cough or sputter.....either my radiator leaks or my exhaust backfires!
OBJ
Re: If my Body were a Car
To True...d:)d:)d:)
12Footer
If my body were a car, It would be a "pea-green"
1952 Wagonqueen Family Truckster.
ricksrster
Rebuild, your carbs. Drink some Sea Foam and you'll be running better than ever. Don't forget to check your compression and change your lower unit lube.
tommays
I had a Big Block till 40 then it was all down hill after the rod went through the block on the left side
Now a 4.3 is about all i can put out :)
Tommays
SpinnerBait_Nut
But what oil to use? So many choices.:devil:
xtraham
"But what oil to use? So many choices"
caster oil..........
aspeck
Dyno or synthetic?
