Lou C
- Joined
- Nov 10, 2002
- 14,153
Just had to do this on my 1988 4.3 Cobra, it was the original unit so I can’t complain too much. A small leak turned into a big one dumping p/s fluid in the bilge. I was able to pick up a good condition used one and NOS actuator and hydraulic cylinder. There are 2 issues with this job:
Access and the 4 cotter pins from He!!. I removed the whole exhaust system and was able to get at it. The big cotter pins that are inserted next to the mounting bolts (15/16th”) are tough to get out. I used a combination of Kroil and Freeze off plus this cotter pin extraction tool to get them out. Both were tough. The bolts came loose pretty easy but it’s hard to get at the bottom one. The other 2 cotter pins (steering arm and steering cable) were not as bad but hard to see. The pins for both came right out. The steering cable I had greased every season so it just slid out. Gotta get this tool for this job. And make sure to grease that cable each year….
