Boilers2000
Thread starter- Joined
- Jun 15, 2018
- 258
Ignition coil has gone bad and needs replaced. Current ignition coil says external resistor required. I tested to confirm a resistor was installed and got 10 volts at the coil with the key on versus 12.8 volts directly at the battery. Picked up new coil and it says external resistor required except if using a TBIV. My engine plate says I have a TBIV, but if that's true why do I have a resistor also. Any insight would be appreciated? I don't seem to see a TBIV plate in the engine compartment so maybe it went bad and wasn't replaced and a resistor was installed instead.
